Homepage
I want to remove the author cover image from the homepage. How do I do that?
You can't do it directly through the interface, but you can do it with a little CSS code. Just log into your admin and go to: Design->Advanced.
Add this into the CSS Ninja area:
.home .two-thirds {
float: none;
width: 100%;
.home .one-third {
display: none;
If I understand what you want correctly, I think this will do it.
