Save link information on string
Thread began 6/11/2020 11:47 am by Juan | Last modified 6/17/2020 8:25 am by Ray Borduin | 322 views | 2 replies |
Juan
When I try to save information of a link on a string, it sabes like this --->. https://www.google.com.mx/ instead of ---> https://www.google.com.mx/ Even the InsertGoTo variable is not working...
<?php require_once('Connections/qrcore.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
$qr_search = new WA_MySQLi_RS("qr_search",$qrcore,1);
$qr_search->setQuery("SELECT qr_control.* FROM qr_control WHERE qr_control.print_qr = ?");
$qr_search->bindParam("s", "".(isset($_GET['qrcode'])?$_GET['qrcode']:"") ."", "-1"); //WAQB_Param1
$qr_search->execute();
$data_link = $qr_search->getColumnVal("link");
if (($qr_search->TotalRows > 0) AND ($data_link != "") ){
$id_qr = $qr_search->getColumnVal("print_qr");
$linkqr = $qr_search->getColumnVal("link");
$InsertQuery = new WA_MySQLi_Query($qrcore);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "qr_scans";
$InsertQuery->bindColumn("qr_code", "s", "".($id_qr) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("link", "s", "".($linkqr) ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = $linkqr;
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
It probably saves fine if you check the database. The issue is probably when displaying the value since we have automatic Cross Site Scripting protection enabled in the mysqli object.
You can disable it in the rsobj.php file, in the recordset, or in each ->getColumnVal() call.
Juan
It works thanks a lot
