Data assist does not show connection
data assist does not load the existing connections, dreamweaver 2019
If it is a MySQLi Connection, then you have to use MySQLi Relational Table in the MySQLi section.
Hello Ray, I do not see the option you describe, can you be more specific
You will need to upgrade to DataBridge v2 in order to use Manage Relational Tables with MySQLi Connections.
