Search working on desktop but not mobile
My Search products box is working on desktop but not on mobile. If you could look at the attached file, perhaps you can see what I'm missing. One Search section begins on line 19 and the other on line 66
The main issue was that your <button> for mobile didn't have name="Search" and your search uses that as the trigger.
Another issue is that you had a <label> tag wrapping both the button and input, which caused iphones to immediately submit when focus was put into the input field.
A third issue is that your top.php include has doctype and head tags and so did your page causing invalid html.
I fixed all of those issues on your products_results-search.php page, but you would have to update the position of the top.php page similarly on other pages.
I did a file compare and clearly see the changes you made. I also think I understand the doctype and head tag redundancies you pointed out. I'll need to fix that. Thanks again for the help!
Your change got the Search working on mobile and I made the header change you suggested, but now we're finding that the Search isn't working on MAC desktops and laptops. If you could take a look, I'd appreciate it.
What browser are you using? I tested on my mac and it seems to work. I tested with Safari, firefox, and Chrome
It is Safari. The example one is a MacBook Air 2019 running Mojave 10.14.16 although several others on different Macs report what I also saw on Browser Stack - you try to place the cursor in the box but it won't stay in the box. If you click the magnifying glass, you get all products as a result as if you did a blank search. Hope that's enough of a clue. As an extra point, the Search does work with Chrome on the same MAC so it does seem browser-related.
I'll have to reproduce it to fix it. I can't seem to see the issue on my mac.
If you can reproduce it then I can do screen sharing with you to reproduce and debug it on the machine where it happens.
It could have something to do with browser settings, firewalls, browser version, OS version. I just wouldn't know where to start without reproducing it first.
If you can get access to a machine that has the issue or even let someone else that has the issue do screen sharing with me, then I could try to figure it out.
Understood and thank you. Can you give me a couple of possible times - either Monday or Tuesday that work for you and I'll put you together with one of the two people that have MACs with the issue.
My son is available anytime today for a screenshare on the Search on Mac not working issue. A link to a video screen capture he did that shows the problem. His contact info is below.
I was able to get this issue resolved with your son.
Your top.php page had a label tag that surrounded both the input and the button. So when you clicked on the input field, you were technically clicking in the <label> and the first form element in that label was the button, so it was submitting the form.
The solution was to replace the label tag with a div tag. I think it may have also worked if I added a for="inputname" attribute to the existing label tag to it knew the label was for the input and not the button, but I don't think the label tag is necessary since you don't actually have a label in the code.
