Error your SQL syntax; check manual corresponds your MySQL server version right syntax near 'ORDER BY priority' line 1 select photoID, productID, filename, thumbnail, enlarged SC_product_pictures productID = ORDER BY priority
When i deleting, editing articles in module "articles"...(Old webasyst shop script)
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY priority' at line 1
select photoID, productID, filename, thumbnail, enlarged from SC_product_pictures where productID = ORDER BY priority
How can I find out what the problem is and fix it?
