DW is changing the code in WA recordset wizard
Thread began 2/09/2020 5:19 am by anonymous | Last modified 2/18/2020 9:50 am by Ray Borduin | 161 views | 6 replies |
anonymous
Created an insert page using Data Assist.
Created a recordset to filter on the field 'TAC'. Using this RS to prevent insert page adding duplicate 'TAC' value submitted from insert form.
Previously I recall just using $_POST['TAC'] as the runtime value format, which worked, however I'm seeing the following in my DW code view
$TACDupeChk = new WA_MySQLi_RS("TACDupeChk",$tacDB,1);
$TACDupeChk->setQuery("SELECT TACdb.TAC FROM TACdb WHERE TACdb.TAC = ?");
$TACDupeChk->bindParam("i", "".((isset($_POST["TAC"]))?$_POST["TAC"]:"") ."", "-1"); //chktac
$TACDupeChk->execute();
And its causing a MySQL error.
When I return to the runtime value in the WA recordset wizard, the value <?php echo ((isset($_POST["TAC"]))?$_POST["TAC"]:""); ?> has replaced $_POST['TAC']
Any ideas?
That is the correct code. You should always check if a variable is set before referencing it. What is the error you get?
PaulBeta Tester
The error "There is an error in your SQL syntax" displays
I have recordset which returns all values in one column so that I can validate the submitted item against it for duplicate entries.
However, as I have placed the filtered recordset above the insert behaviour, the $_POST['TAC'] value has no value since the form hasn't been completed, I'm assuming that this maybe causing the error?
But then how do I check for duplicates if the filtered recordset is placed after the insert server behaviour?
I don't think this is a problem with that line of code. Can you give me a URL to reproduce the error and FTP access? I'll debug it and let you know what is going wrong.
PaulBeta Tester
PM sent.
It looks like the FTP information you gave me goes to a sub-directory so I can't view your files. Please update it and I can try to take a look.
I currently get a SQL syntax error on that page. If you update your rsobj.php file you can turn on Debug and then it will give you a more complete error message.
PaulBeta Tester
resolved. - issue lay in the sql table
