Check new user issue
Have use "Check New User" successfully with the "ADD" function.
Now trying to use same but with the "UPDATE" function and getting the following error
Fatal error: Uncaught Error: Class 'WA_MySQLi_Auth' not found in /home/riclau7/member.lawg.cap.gov/Reg_SAREX/SarexRegUpdateAsset.php:7 Stack trace: #0 {main} thrown in /home/riclau7/member.lawg.cap.gov/Reg_SAREX/SarexRegUpdateAsset.php on line 7
In the attached example case -- trying to check data field "aircraft" to insure that it has not been already entered to the database.
Do i have a syntax error or is it that cannot use that function in conjunction with Update?
Rick L
