File wont upload from page Databridge
Thread began 1/06/2020 11:26 am by Jess | Last modified 1/06/2020 12:12 pm by Ray Borduin | 461 views | 3 replies |
Jess
I´m trying to get my page to upload a file but it keeps failing weather I use the field from Dreamweaver or from databridge under WA.
I have tried several sollutions and have made sure my folder is able to write files into it.
I have attached the files that causes fails and hope that something can come from this. I would apriciate an updated guide for the new data bridge for how to insert and upload files with the data bridge plugin.
Best Regards
Jess
You are using the file manager, so you shouldn't be using a separate upload file server behavior. The file manager uploads the file before the form is even submitted.
The Upload File server behavior is for use with input type="file" form elements without the file manager interface.
Jess
So if I wanna upload a file from my computer, how do I select the file I want (and later rename when uploading)?
You could use either the file manager, or a simple file upload field. If you are just uploading a single file and don't need to switch or edit folders then you could probably just use a file input field.
