I am Getting some Error when i try to use the checkout wizard in any page
I am getting this error when i run checkout wizard in cart
I think the first error might be the cause of the second. I just updated the installer to try to fix it. I don't have CS6, so I can't test it directly.
Please reinstall either Data Bridge v2 or ECart to get the updated file. It shouldn't matter which one. The order of installation is not important either.
Let me know if that fixes the problem. If not, I'll probably need to do screen sharing to reproduce and debug this on your machine since I don't have a copy of CS6 to test with.
I am using CS3 - Not Cs6, so used the versions for cs3
Would you like to do a screen sharing session to see if I can fix the errors so you can properly evaluate the software? Or I could just process the refund now if you would prefer.
Yes, the refund seems to be a better option until i can upgrade my system..
Your refund has been processed. Please allow up to 5 business days for it to show on your credit card statement.
