update fails post
Thread began 1/05/2020 6:51 pm by Richard | Last modified 1/06/2020 10:08 am by Ray Borduin | 122 views | 1 replies |
Richard
update fails post
i have a php file using "update" that is called by another action to simply post a "YES" into a data record.
But all attempts, the update command fails to execute leaving the recordset unchanged.
Other uses of "Update" in other php files work fine but
this is a stand alone (aka its called, executes update and then passes on to another php file)
The record set filter is located in a session variable and i have verified the variable exists and contains the correct value.
NOTE -- the attached file has a recordset added in addition to just using the "update" for trouble shooting. Using the MySQLi Update solo does not function
I can not detect anything wrong. Could you check my code and advise me on why MySQLi Update is not posting
Rick L
This page has a trigger of "always" but uses the value from a form that wouldn't have been submitted yet.
Then the form that has the hidden form field doesn't have a submit button, so it can't be submitted at all.
I think the solution to update the reocord without displaying the page is to update line 17 from:
$UpdateQuery->addFilter("capid", "=", "s", "".((isset($_POST["hiddenFieldcapid"]))?$_POST["hiddenFieldcapid"]:"") ."");
$UpdateQuery->addFilter("capid", "=", "s", "".(isset($_SESSION['MM_Username'])?$_SESSION['MM_Username']:"") ."");
Then you can get rid of the <!DOCTYPE tag and everything below it. Since this page is never displayed it doesn't need any html content.
