Check New User Issue
Getting PARSE syntax error when attempting to use the "Check New User"created with WebAssist
Issue is with the syntax of attempting to send the form variable "capid" in the URL call string to the "if found" webpage.
have the same in use but the pass variable is a session variable,,,, for this application i want to just pass the form variable
Can you please check my syntax
Error text is:
Parse error: syntax error, unexpected '"', expecting '-' or identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in /home/riclau7/member.lawg.cap.gov/Reg_Acad_Public/AcadRegAdd.php on line 12
Full php file is attached for reference
