Ecart 6
Is there an easy way to upgrade from ecart 4 to 6 or do you suggest rebuilding the whole store? We used our own CSS framework and it would be nice to just update files and use the same settings.
Does it show in the list of eCart objects? You may be able to just open the eCart object and click "ok" to update it. You would still likely want to go through and update the view cart and checkout pages to use the latest version, but it might not be necessary. I know it would work updating eCart 5 to 6, but I'm not so sure with skipping a version.
You might want to sign up for an hour of premier support. I could help you get it updated and avoid any unnecessary work.
Ray I think I will hire you to help me because I have a time constraint and quite frankly I have not used dreamweaver in 4 years. I am going to start this part next week.
Just call the number at the bottom of any page on this website when you are ready to schedule the screen sharing session and we can coordinate a time.
