activation fails appear
Thread began 12/10/2019 8:46 pm by Richard | Last modified 12/11/2019 6:01 pm by Ray Borduin | 867 views | 5 replies |
Richard
For MySQLi Server Bahavious with Dreamweaver CS5.5...
have installed the extension via the extensions manager.
upon opening dream and a php file
extension is present but no activation screen appears. Hence have not been able to activate the product.
How do i get the activation screen to appear and hence activate the product?
First you would open any page and that should cause the secondary installer to run. After that runs you need to restart Dreamweaver and then open a a page and access any of the webassist menu items. That should then pop up the serial window. If you have issues, post your phone number in the private area of a response and I'll give you a call tomorrow to do screen sharing and help you get it working.
Richard
MySQLi activation problem
Found issue with activation but now have a connect issue.
Per suggestion - using the "top" nav bar engaged the activation. Using the sub menus does not.
So i activated, connections established but all attempts to build a recordset with the connection fail.
Can you give me a call and help get my package operational. Thks Rick Lauterbach. See Private for #
That phone number just takes me to a survey. You may have posted the wrong number. Maybe try calling me using the number at the bottom of every page of the webassist site.
Richard
CS5.5 issues
Ray -- have run into some additional non-functions items. i was just testing some of the report items
DisplayTotalRecords fails to complete
Dynamic Data table features fail to see the MySQLi recordsets
Can we connect up again and address --- correct cell number in privates
Thanks Rick Lauterbach
We were able to get this worked out in a screen sharing session. Let me know if you have any more issues I can help with.
