Does eCart6 support PayPal Standard?
My existing PayPal Standard has abruptly stopped working. Will eCart6 help?
We have eCart Express integrated... it is a better solution than standard. Still free but don't require IPN. eCart 6 will allow you to re-do your checkout using this more modern solution.
Where would this be patched together? eCart feeds confirm, would this replace confirm?
You would replace your entire checkout process. From the checkout form to the success page by re-running the checkout wizard.
So is Express the same as Payflow Pro or Payments Pro or Payments Advanced? The credentials are only pre-filled for Payments Pro. Is this the free Express?
The credentials are the same as payments pro, but it is free.
