MySQLi query where target from $_GET[] Query not returning values on page
Thread began 11/05/2019 3:58 pm by Michael | Last modified 11/06/2019 7:55 pm by Ray Borduin | 445 views | 6 replies |
Michael
Hello Support,
Please my MySQLi query where target from $_GET[] Query not returning values on page. Please see code below
$rsValidateParticipant = new WA_MySQLi_RS("rsValidatet",$DBMS,10);
$rsValidateParticipant->setQuery("SELECT regno, title, surname, othernames, state, country, assembly, sex, maritalstatus, age, phone, email, @curRow := @curRow + 1 AS sn FROM registration JOIN (SELECT @curRow := 0) r WHERE assembly = ? ORDER BY assembly ASC");
$rsValidateParticipant->bindParam("s", "".(isset($_GET['assembly'])?$_GET['assembly']:"") ."", "-1"); //colname
$rsValidateParticipant->execute();
The code is to pull all records based on the selected Assembly but when the assembly is selected from the drop down menu, nothing happens; no data is loaded on the page
Attached is the page.
Thank you
I'm not familiar with the SQL syntax you are using. Does it work to return all rows when you remove the parameter and WHERE Clause?
You can write the resulting SQL statement to the page like:
<?php echo($rsValidateParticipant->debugSQL()); ?>
Then you can copy and paste that SQL statement into phpMyAdmin and debug it there to see if the parameter is set correctly and if there is something else wrong with the SQL statement.
Michael
Michael
The code <?php echo($rsValidateParticipant->debugSQL()); ?> is not showing any error but rather echoing the SQL statement.
This SQl statement "SELECT regno, title, surname, othernames, state, country, assembly, sex, maritalstatus, age, phone, email, @curRow := @curRow + 1 AS sn FROM registration" runs perfectly well on phpMyAdmin
What about after adding the where clause. Does the SQL statement look correct and return the correct rows on phpMyAdmin then?
Michael
Yes sir
I'll need FTP access and a URL to fully debug. If the query looks right and returns a result in php myAdmin, then it should work.
