Is there MySQL code still in the helper file? (Not MySQLi)
Also trying to figure out how "Logged in as user" is defined. I saw where Ray mentioned in another post that the definition can vary. Could you provide an example with UserEmail?
The mysql code in the helper should only be called if you are using a mysql connection. The logged in as user rule in php mysql would be defined based on the authentication server behavior being applied with the title "user".
You can create custom rules with DataBridge to make more complex rules to cover any circumstances you need.
