I can't seem to get the repeat region feature to work for this particular recordset.
Thread began 9/13/2019 6:01 am by Adam | Last modified 9/16/2019 10:06 am by Ray Borduin | 292 views | 2 replies |
Adam
This is the first time I haven't been able to get the repeat to work...but this is the most complicated query I've worked with as well. In phpmyadmin, it returns the proper number of records; however, on the site it just returns one. Attached is the code. I've made sure the webassist code is marked with a 0 and not a 1 to show all, but still no luck. I've also tried the query with "FROM `class`, `survey2` WHERE class.studentid = survey2.studentid" instead of the INNER JOIN / ON method. Don't know if that matters, but both return the same results.
Any help would be greatly appreciated.
class.php
Adam
Well...now I'm seeing them. They're just really spread out. Not sure what happened.
class.php
Adam
Okay. Feel free to close this. I had a </div> in the wrong spot. :-/
