MySqli Login stay on same page
Thread began 8/29/2019 8:37 am by Adam | Last modified 9/12/2019 10:06 am by Ray Borduin | 1238 views | 13 replies |
Adam
MySqli Login stays on same page
I just set up a page to use as a login, but when I attempt to login, it just stays on the same page and tacks on:
/?username=admin&password=admin&LOGIN=LOGIN
to the end of the url. It never redirects to the success page. The same thing happens when it fails.
I just have a simple form (see below)...and then using the webassist server behavior Login User.
If i change the method to post, it just goes to the failed page no matter what username and password i put in the fields.
Any thoughts?
<form action="" method="get" name="user">
<div>
<input id="username" name="username" type="text" placeholder="Username...">
</div>
<div>
<input id="password" name="pwd" type="password" placeholder="Password...">
</div>
<div>
<input name="LOGIN" type="submit" value="LOGIN">
</div>
</form>
This is what was automatically added to the page.
<?php require_once('../Connections/Claudia.php'); ?>
<?php require_once('../webassist/mysqli/authentication.php'); ?>
$Authenticate = new WA_MySQLi_Auth($Claudia);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = ($_SERVER["REQUEST_METHOD"] === "POST");
$Authenticate->Name = "user";
$Authenticate->Table = "users";
$Authenticate->addFilter("username", "=", "s", "".((isset($_GET["username"]))?$_GET["username"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_GET["pwd"]))?$_GET["pwd"]:"") ."");
$Authenticate->RememberMe = (true);
$Authenticate->SaveLogin = (true);
$Authenticate->AutoReturn = false;
$SuccessRedirect = "home.php";
$FailedRedirect = "fail.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
You are using the trigger "any form post", but you have a form method "get" instead of "post".
I'd fix this by updating your <form> to use post method. Then find and replace any reference to $_GET and change it to $_POST
Adam
thank you! i guess i tried those things all separately...but never all at once. Thanks again for your help.
Adam
I'm trying the Log In User again on another page...and the form just seems to refresh and never redirects to the index.php page. Any thoughts?
<?php require_once('../Connections/Micro2.php'); ?>
$Authenticate = new WA_MySQLi_Auth($Micro2);
$Authenticate->Table = "teachers";
$Authenticate->addFilter("username", "=", "s", "".((isset($_POST["username"]))?$_POST["username"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->storeResult("team", "team");
$Authenticate->storeResult("username", "user");
$SuccessRedirect = "index.php";
$FailedRedirect = "";
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Login</title>
<link href="micro.css" rel="stylesheet" type="text/css">
<link href="https://fonts.googleapis.com/css?family=Fredericka+the+Great|Homenaje&display=swap" rel="stylesheet">
</head>
<body>
<div id="main" align="center">
<div class="header"> LOGIN </div>
<div>
<form action="" method="post">
<div ><label for="username">Username:</label> <input name="username" type="text" id="username"><br></div>
<div ><label for="password">Password:</label> <input name="password" type="password" id="password"><br></div>
<input name="submit" class="submit" type="submit" value="Submit" />
</form>
</div>
<div>
</body>
</html>
Maybe a blank line of code or space in the code? If you attached the page I might be able to spot it.
Adam
That was the entire page that is pasted under my question. I attached it as well to this reply.
login.php
That looks ok. Maybe something in your Micro2.php connection file? Usually a redirect not working is because of extra code, errors, or line breaks that appear above the redirect. If I had a URL to redirect and FTP access then I could debug it further for you and try to find the source of the problem.
Adam
okay.
it would need to redirect to index.php..and login in private message.
not sure if i did it right, so let me know if it doesn't work.
what is the website url?
Adam
micro2.adamhaynes.com
