Warning: mail(): Failed connect mailserver
Warning: mail(): Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\xampp\htdocs\NewBiz\form\neha.php on line 53
You probably don't have an SMTP server installed on the server you are working on. You can contact your hosting provider to find the correct server settings to use for connecting to your SMTP host.
