Mysql 5.7 Upgrade
Thread began 6/24/2019 7:46 am by Juan | Last modified 6/24/2019 1:42 pm by Ray Borduin | 233 views | 1 replies |
Juan
Mysql 5.7 Upgrade
My server is asking to upgrade from Mysql 5.6 to Mysql 5.7. I want to make sure that I will not have any problem with data bridge at the upgrade moment. Because I cant downgrade to 5.6.
At the moment to upgrade I get this sign:
MySQL enables "strict mode" by default as of version 5.7. Strict mode controls how MySQL handles invalid or missing values in data-change statements such as INSERT or UPDATE. Applications not built with strict mode enabled may cause undesired behavior; please verify applications using MySQL are compatible before upgrading. More information about strict mode is available here
Can I upgrade?
Regards
Probably... you may have to update some complex SELECT statements if they aren't perfectly formatted, but any issues you find should be easy enough to fix.
