Error Inspecting SQL
Thread began 6/12/2019 3:10 pm by Juan | Last modified 6/20/2019 6:33 pm by Ray Borduin | 1659 views | 10 replies |
Juan
I download my site and install all on local server. The connection SQLi is done correctly but when I try to modify any binding. Says Error inspecting SQL and tables cant be found. Even is the tables are on database. Is any cache or something I need to delete? In other site I test any table are displayed.
Go to the connections tab and edit your connection... click the test button there and see if there is an error. For some reason it doesn't seem to be connecting to your database. It could be cached in the bindings window.
Juan
It only happen on the query builder. On connection panel says connection success, also on simple query builder display tables but on advanced query builder dont display any information. Any suggest?
Try reinstalling DataBridge and see if that fixes it. If not, post your phone number in the private area and I'll do screen sharing with you in order to debug it.
Juan
Hi I have reinstall all and still not working. Sent you attached my skype and phone number. I test on two computers and have the same problem.
I'll message you in Skype to set up a screen share in order to look into this issue.
Juan
I am ready on skype.. let me know when you are ready.
I've just uploaded an update to the extension that should fix this problem. Please reinstall and try again.
Juan
Tested work fine now. Thanks
PatriceWebAssist
So we download which one? Will it affect any older work?
seeing DataBridge_235
