MySQLI Query Export to XML File
Thread began 5/20/2019 8:40 am by anonymous | Last modified 6/11/2019 8:20 am by Ray Borduin | 1102 views | 9 replies |
anonymous
I have a query below and I need to export the data on the page to an XML file. Is it possible to do this with the Dreamweaver Extension?
$agreements2 = new WA_MySQLi_RS("agreements2",$sdpc_i,0);
$agreements2->setQuery("SELECT *, clause_agreement_type.clause_agreement_typeID as theclause_agreement_typeID, clause_obligation.clause_obligationID as theclause_obligationID, obligations.obligationID as theobligationID, benchmarks.benchmarkID as thebenchmarkID, contract_clauses.clauseID as theclauseID FROM agreement_types left join clause_agreement_type on agreement_types.agreement_typesID = clause_agreement_type.agreement_typesID left join contract_clauses on contract_clauses.clauseID = clause_agreement_type.clauseID left join clause_obligation on clause_obligation.clause_agreement_typeID = clause_agreement_type.clause_agreement_typeID left join obligations on obligations.obligationID = clause_obligation.obligationID left join obligation_benchmark on clause_obligation.clause_obligationID = obligation_benchmark.clause_obligationID left join benchmarks on obligation_benchmark.benchmarkID = benchmarks.benchmarkID WHERE agreement_types.agreement_typesID = ?");
$agreements2->bindParam("i", "".(isset($_GET['agreement_typesID'])?$_GET['agreement_typesID']:"") ."", "-1"); //colname
$agreements2->execute();?>
HTML is just a form of XML... So of course you can create an xml page from a recordset result. Just write the XML code and add values from the database where you want them.
anonymous
So I did this and I get XML code for one of the records but, there should be three records. Do you know where I went wrong?
<?php require_once('Connections/sdpc_i.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
if ("" == "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "sdpc_login";
$RestricAccessRedirect = "error.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
$state = $_GET['state'];
$agreement_typesID = $_GET['agreement_typesID'];
$category = $_GET['category'];
$query = new WA_MySQLi_RS("query",$sdpc_i,0);
$query = "SELECT * from ((SELECT agreement_typesID, agreement_name, state, description, category as thecategory, latest, public, concat('https://sdpc.a4l.org/agreements/',file_pdf) as agreement_file_pdf, concat('https://sdpc.a4l.org/agreements/',file_doc) as agreement_file_doc FROM agreement_types where state = '$state' and agreement_typesID = $agreement_typesID and category = '$category') t1 left join (SELECT * FROM agreement_vendor_types) t8 on (t1.agreement_typesID = t8.agreement_typesID) left join (SELECT * from clause_agreement_type) t2 on (t1.agreement_typesID = t2.agreement_typesID or t2.agreement_type_vendorID = t8.agreement_type_vendorID) left join (SELECT * from contract_clauses) t3 on (t3.clauseID = t2.clauseID) left join (select * from clause_obligation) t4 on (t4.clause_agreement_typeID = t2.clause_agreement_typeID) left join (SELECT * from obligations) t5 on (t5.obligationID = t4.obligationID) left join (SELECT * from obligation_benchmark) t6 on (t4.clause_obligationID = t6.clause_obligationID) left join (SELECT *, benchmarkID as thebenchmarkID from benchmarks) t7 on (t6.benchmarkID = t7.benchmarkID))";
$result = $sdpc_i->query($query);
// Associative array
$row=mysqli_fetch_array($result,MYSQLI_ASSOC);
// Free result set
mysqli_free_result($result);
mysqli_close($sdpc_i);
function to_xml(SimpleXMLElement $object, array $row)
foreach ($row as $key => $value) {
if (is_array($value)) {
$new_object = $object->addChild($key);
to_xml($new_object, $value);
} else {
// if the key is an integer, it needs text with it to actually work.
if ($key == (int) $key) {
$key = "$key";
$object->addChild($key, $value);
$xml = new SimpleXMLElement('<data/>');
to_xml($xml, $row);
print $xml->asXML();
header('Content-Type: application/xml; charset=utf-8');
header('Content-Language: en');
header('Cache-Control: no-store, no-cache, must-revalidate');
header("Content-Length: ".filesize($filename));
header("Date: ".gmdate('D, d M Y H:i:s T'));
$query
= new WA_MySQLi_RS("query",$localhost,0);
$query->setQuery("SELECT * from ((SELECT agreement_typesID, agreement_name, state, description, category as thecategory, latest, public, concat('https://sdpc.a4l.org/agreements/',file_pdf) as agreement_file_pdf, concat('https://sdpc.a4l.org/agreements/',file_doc) as agreement_file_doc FROM agreement_types where state = ? and agreement_typesID = ? and category = ?) t1 left join (SELECT * FROM agreement_vendor_types) t8 on (t1.agreement_typesID = t8.agreement_typesID) left join (SELECT * from clause_agreement_type) t2 on (t1.agreement_typesID = t2.agreement_typesID or t2.agreement_type_vendorID = t8.agreement_type_vendorID) left join (SELECT * from contract_clauses) t3 on (t3.clauseID = t2.clauseID) left join (select * from clause_obligation) t4 on (t4.clause_agreement_typeID = t2.clause_agreement_typeID) left join (SELECT * from obligations) t5 on (t5.obligationID = t4.obligationID) left join (SELECT * from obligation_benchmark) t6 on (t4.clause_obligationID = t6.clause_obligationID) left join (SELECT *, benchmarkID as thebenchmarkID from benchmarks) t7 on (t6.benchmarkID = t7.benchmarkID))");
$query->bindParam("i""".($_GET['state'])  ."""-1"); //state
$query->bindParam("i""".($_GET['agreement_typesID']); //agreement_typesID
$query->bindParam("i""".($_GET['category'])  ."""-1"); //category
$query->execute();
function to_xml(SimpleXMLElement $object, array $row)  {
  foreach (
    if (
is_array($value)) {
$new_object $object->addChild($key);
to_xml($new_object$value);
    } else {
$key "$key";
$object->addChild($key$value);
ob_start
while (!
$query->atEnd()) {
to_xml($xml$query->Results[$query->Index]);
  print
$xml->asXML();
$query->moveNext();
$output ob_get_contents();
ob_end_clean();
header("Content-Length: ".strlen($output));
echo(
$output);
anonymous
Thank you for this. I am still getting this error message:
error on line 7 at column 6: XML declaration allowed only at the start of the document
Here is the code we have:
ini_set('display_errors', 1);
ini_set('display_startup_errors', 1);
error_reporting(E_ALL); ?>
if ("" == "") {
$query->bindParam("s", "".($_GET['state']) ."", "-1"); //state
$query->bindParam("i", "".($_GET['agreement_typesID']) ."", "-1"); //agreement_typesID
$query->bindParam("s", "".($_GET['category']) ."", "-1"); //category
$query->execute();
} else {
$key = "$key";
ob_start();
while (!$query->atEnd()) {
to_xml($xml, $query->Results[$query->Index]);
$query->moveNext();
$output = ob_get_contents();
ob_end_clean();
echo($output);
Please attach the page you are working on.
anonymous
Here you go. Thanks
Lisa
download_pod.php
This appears to be an issue with your recordset data. Perhaps you have a column named "XML" and it is complaining that you can't have a tag with that name in the middle of your document.
I could debug this for you and get it working, but since the issue is with a hand coded and not supported section of your code I'd have to bill you for an hour of premier support in order to fix it ($100).
If you are interested you can just reply to this thread with FTP information and a URL to view the current page and I'll get it working.
anonymous
Actually, the recordset data is fine. Not mention of XML there. It seems to have to do with this code:
ob_start();
$query->moveNext();
ob_end_clean();
echo($output);
It is echo or printing the output or XML twice. When I remove one of them I get the XML data correctly but, I am still having the original issue of the data not repeating all records.
I can't effectively debug hand coded sections without direct access to the page for debugging.
