Error on insert record MSLI
When you try to execute this small code it says:There is an error in your SQL syntax.
Attached the file.
Attached the file.
Open your queryobj.php file and change the setting for Debug to true instead of false. That should show you a better error message. It may be a required field is not being included in the insert. By turning on debug it will give you the full error message and help you determine the cause and solution.
