When using the Delete, insert or Update
Thread began 3/30/2019 2:15 pm by James | Last modified 12/28/2019 12:12 pm by Ray Borduin | 1276 views | 10 replies |
James
Hi, when trying to update using any of these and when I go to the Drop down for the trigger and select either recordset empty or not empty.
It throws errors. It looks like its leaving off the $ sign
It is putting in
if (!(Special->TotalRows === 0)) {
And I have to manually fix it by adding the $
if (!($Special->TotalRows === 0)) {
When I try to update after using the drop down, it goes into a loop
Thank you for reporting this problem... I'll get this fixed and get out an update.
James
Thank you sir!
I uploaded the update today. If you reinstall it should be fixed.
James
ok. I will download it and give it a try.
James
Looks like its working good now!
Thanks!
James
Ray,
After updating my databridge extension.
The options above have disappeared.
So, If I have a recordset that is empty, I can not use that to insert a new record.
Did you take this option out?:
The option appears for me. Is the recordset displaying in the server behaviors properly?
James
Yes.
Try reinstalling DataBridge... if you still have the issue then post your phone number and I'll do screen sharing with you to debug and determine what is causing this issue since I can't reproduce it on my end.
