XAMPP PHP 7.2.13 Windows 10 - Framework insert plugin not working properly
Thread began 12/17/2018 3:01 pm by Henry | Last modified 7/26/2019 8:13 am by Ray Borduin | 1418 views | 7 replies |
Henry
Firstly, my external website is now on PHP 7.2 and it's running well! (Used a hosting provider with default configurations). I use eCart, MySQLi behaviours and Databridge 2.
I tested/developed on XAMPP PHP 7.1 on Windows 10 and the Framework insert worked but when I upgraded to XAMPP PHP 7.2 19 I get the Framework.php error "Framework file not found: folder/folder/filename.php" (using ver 2.0 framework.php)
I've spent a few days trying to figure it out. and am guessing it's a XAMPP configuration thing ... can you lead me in the right direction to resolve this? Thanks.
ps I've upgraded to Windows 10 most current version 8913
Please post a US phone number or Skype contact information and I'll take a look in a screen sharing session to see if I can figure out why it isn't working.
Henry
Got back on trying to figure this out.
Did some testing and found out that if the WA_Include was in a folder outside the folder of the file it is in eg WA_Include("../folder/folder/filename.php"); it doesn't work ie. I get the Framework.php error "Framework file not found: folder/folder/filename.php" ... but ... if the WA_include folder is in the same folder of the file it is in it works eg. WA_Include("filename.php");. This only happens in XAMPP newest versions.
I believe I have the latest framework.php file - copy attached.
I'm now guessing that framework.php needs some revision to accommodate newer versions of XAMPP. What do ya think?
PS I also created a version of my file within the XAMPP test environment where the WA_Include was pointing directly to the file in my case on my C: drive and got the same results ie. works if file in same folder but not if it is in a different folder.
It is possible your framework/library.php file is out of date. I'd need to do screen sharing, or get FTP access and a URL to debug and be sure. I don't think it is an issue with the extension and latest versions of XAMPP, but potentially an issue with your server settings.
Henry
Attached is the library.php I've got. Is it up to date?
No... both files seem older. I have attached updated versions.
framework.php
library.php
Henry
I installed these two files (ps. I like that there are version numbers within them) and it didn't make a difference.
I'll do some more testing and double ensure that things like cache are cleared. After that I'll get back to you.
Also, I'll look at the XAMPP setup again. I did a vanilla install. Put all my files within the htdocs folder. I'll look at that again as well.
I can do screen sharing if you still have issues with the latest version and help you figure out what is going on. I'll just need you to post your phone number in the private area of a reply and I can call you to set it up.
