Repeat Selection
Thread began 9/09/2009 1:47 pm by meister281653 | Last modified 9/09/2009 5:01 pm by Jimmy Wu | 681 views | 1 replies |
meister281653
Repeat Selection
I didnt understand that:
The repeat selection server behavior is a DataAssist server behavior. It is primarily used in combination with the repeat region server behavior to do more advanced displays of records. Using repeat selection along with the repeat region server behaviors you can create a display for your records that repeats horizontally, then drops down to the next line to repeat vertically until all your records are displayed.
Are there any visual demos?
Denis
Jimmy Wu
If you open up the Repeat selection server behavior under DataAssist, and go to the Help from there, there is a detailed explanation of what the server behavior does that may clarify your misunderstanding.
Basically, The Dreamweaver Repeat Region will only repeat vertically, but the DataAssist Repeat Selection allows you to repeat horizontally as well.
