extension manager said extension installed needs dreamweaver 9 greater dreamweaver cc
Tried installing from extension manager and from command line extension manager (received error code 160). Cannot install extension, please advise.
You have to use one of the free third-party extension managers since Adobe dropped support for theirs.
The two most common and best supported options are:
http://www.projectseven.com/products/ex-man/info.htm
https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
even with the third party extension manager, the plugin MYSQLi server behaviors seems doesn't install correctly. I saw Tab webassist > Database > Model Database, but when click, a small empty window pop up.
Besides, i saw the server behavior, but is inactive.
Did the secondary installer run when you re-opened dreamweaver after installing from the extension manager?
Server Behaviors have problems when working in live view. Try switching to design view and see if that enables your server behaviors panel.
Another issue might be your site definition. You need to have a testing server defined and a database connection defined before you can model the database and use the server behaviors.
Do i need to reinstall my dreamweaver?
Yes, I opened the third extension manager when using dreamweaver, it need to be closed it is?
after uninstall, i still see webassist tab, but not model database nor server behaviors.
Please post a US phone number or Skype contact information and I'll do a screen sharing session to debug this with you and make sure to get it all working properly.
Have just purchased.
Multiple attempts to install on Mac DW CC 2019 with no success, including using the information here.
Uninstalled DW. Reinstalled.
Uninstalled Extension using http://www.projectseven.com/products/ex-man/info.htm
Reinstalled Extension
Turned off Live view
No WebAssist Menu Items
No WebAssist folder in DW:Configuration:Shared
Note Extension Installer still says it is installed.
Created a new site
PHP file open in DW.
HELP!!!!
Try installing with:
