Software does not insert data
Thread began 3/27/2018 6:26 am by Jason | Last modified 3/30/2018 7:57 am by Ray Borduin | 2967 views | 14 replies |
Jason
Hello,
The webassist mysqli server behavior (insert) is not working, I double checked your documentation if I was doing it ok and 2 servers tested with same behavior. I checked my sql / php logs and they both have no errors but data is not inserted in database. I have added the code below for you to view.
Please help.
This code looks correct. Can I see the form html? Is it redirecting to the Thanks.php page?
Jason
Hello Ray,
Attached is the form. Yes when you click send (submit) it does change page. All my bindings are also set from what I see it seems good.
You have your form action set to "Thanks.php". That means you aren't even submitting the form to the page and giving it a chance to do the insert.
Change it to action="" and let the redirect take it to the Thanks.php after the insert and that should solve the problem.
Jason
I thank you very much Ray not sure why it inserts this automatically but ill keep an eye out next time.
works with <form action="" method="post">
Jason
Update now cannot login since fix
My shared hosting provider don't work with this code which is automatically generated by webassist. I did do a test on my local server and it runs fine. Is there any server settings which would cause this running on PHP5.6?
Warning: call_user_func_array() expects parameter 1 to be a valid callback, first array member is not a valid class name or object in /home/gatewayc/Gateway.jayandsilentbill.info/webassist/mysqli/authentication.php on line 92
Fatal error: Call to a member function execute() on boolean in /home/gatewayc/Gateway.jayandsilentbill.info/webassist/mysqli/authentication.php on line 93
You probably haven't updated your database connection to work with your live server. The code is probably ok, it just doesn't have the correct database connection or tables in the live database.
Jason
Actually its a duplicate server version and one is hosted. Other pages with the same include (below) are working fine.
<?php require_once('Connections/localhost.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
I just retested on local server with same code / PHPversion / DB structure and code does work, just not on hosting.
Can I get a URL and FTP access to test? Usually that error means a bad server, username, or password, but I can debug further to verify.
Jason
Please see PM details.
