HTTP Error Code 406 Not Acceptable
This is a strange one! The database connects just fine... The bindings panel connects and sets up a connection to the database table... but when it is set up the bindings panel will not show the fields. Instead it says "HTTP Error Code 406 Not Acceptable"
I completely reinstalled the creative cloud and Dreamweaver (using the cc cleaner as well) and reinstalled everything, but still get the same issue. I can hand-code the php if necessary, but would like to know what caused this so I can avoid it again :)
Repeat behaviors works good. Not tried adding the insert record behavior, but I am sure that will too, it just won't show the fields in the bindings panel! smiles!
