why cant mysqli connections be chosen from connection lists. Only mysql connections can be chosen?
Thread began 1/27/2018 2:49 pm by Jess | Last modified 8/06/2018 10:48 am by Ray Borduin | 594 views | 5 replies |
Jess
I have tried to use both the data assist and Security Assist part of the databridge extension. I can´t choose any mysqli connections that i have used before (and paid for that extension as well), I can only choose mysql connections which is not the desired type of connections as the rest of the pages have been updated to Mysqli with your plugin. How is this solved? I´m using Dreamweaver CS6.
I saw posts before purchasing the databridge extension from 2014 where i was to be developed soon which gave me the clear thought that it would have been solved in 3 to 4 years. If this is not solved within the 15 days from today, I will ask to have my money refunded as it´s not something that can be used.
If there is a beta test or update available, please let me know as multiple projects are waiting for this.
Please advice as a lot of the functions which is why i purchased the plugin is not supported with your mysqli extension.
Best Regards
Jess Larsen
The next version of DataBridge will be updated to work with php 7. For now you are welcome to try the ALPHA release that has a new email code base that works with php7:
Here is a build you can test: http://www.webassist.com/DataBridge_V2ALPHA.zxp
Serial Number: h3O9J-ZGczX-0yWgD-GHWo3
Jess
Thanks for the update, however....
Update for Ray.
I fixed the error message. If you reinstall it shouldn't happen anymore. SecurityAssist isn't done yet in this build, but I'm working on that now so it should be ready soon.
DataAssist encryption options are still available and you can use encryption for inserts as well. In the second tab of the wizard there is a button for "configure field settings" That allows you to set encryption types for each column.
Jess
Saw a new release
Hi Ray.
I saw you made a release in december 2017 and was wondering if all the issues were fixed there for the databridge extension?
I hope to hear from you soon.
Best regard
Jess Larsen
I'm fixing issues as they are reported, so the latest version should have everything I know of fixed.
