Master/Details page
Thread began 7/10/2017 6:05 am by Leon | Last modified 7/12/2017 9:08 am by Ray Borduin | 1412 views | 4 replies |
Leon
Master/Details page
I am trying to build a master/details page:
master:
<?php require_once('Connections/mitoWebsiteMSQLI.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
//query lists all database records?>
$masterAllRecordset1 = new WA_MySQLi_RS("masterAllRecordset1",$mitoWebsiteMSQLI,10);
$masterAllRecordset1->setQuery("SELECT * FROM completedProjects");
$masterAllRecordset1->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
<ul>
while(!$masterAllRecordset1->atEnd()) {
<li><a href="details1.php?bymission_id=<?php echo($masterAllRecordset1->getColumnVal("mission_id")); ?>"><?php echo($masterAllRecordset1->getColumnVal("project_name")); ?></a></li>
$masterAllRecordset1->moveNext();
$masterAllRecordset1->moveFirst(); //return RS to first record
</ul>
</body>
</html>
Details:
$details1Recordset1 = new WA_MySQLi_RS("details1Recordset1",$mitoWebsiteMSQLI,1);
$details1Recordset1->setQuery("SELECT * FROM completedProjects WHERE mission_id = ?");
$details1Recordset1->bindParam("i", "".(isset($_GET['bymission_id'])?$_GET['bymission_id']:"") ."", "-1"); //colname
$details1Recordset1->execute();
<!doctype html>
<html>
<head>
</head>
<body
<?php echo($details1Recordset1->getColumnVal("project_name")); ?></body>
</html>
This is a simple Master/detail. I am having issues with the details page returning no value from the master page. It seems that the master page does go to the details page when the link is clicked, but no data is returned or printed to the page on the details page.
Please help me resolve this
Thank you.
Jason Byrnes
the code for the body tag on the details page is off. edit:
<body
<body>
Note the change of "<body" to "<body>".
Leon
Thank you for the correction. I have made the changes and started again.
Master:
$master2Recordset1 = new WA_MySQLi_RS("master2Recordset1",$mitoWebsiteMSQLI,10);
$master2Recordset1->setQuery("SELECT * FROM completedProjects ORDER BY project_name ASC");
$master2Recordset1->execute();
<!doctype html>
<html>
<head>
</head>
<body>
<ul>
while(!$master2Recordset1->atEnd()) {
<li><a href="details2.php?mission_id=<?php echo($master2Recordset1->getColumnVal("mission_id")); ?>"><?php echo($master2Recordset1->getColumnVal("project_name")); ?></a></li>
$master2Recordset1->moveNext();
$master2Recordset1->moveFirst(); //return RS to first record
</ul>
</body>
</html>
Details:
$details2Recordset1 = new WA_MySQLi_RS("details2Recordset1",$mitoWebsiteMSQLI,1);
$details2Recordset1->setQuery("SELECT * FROM completedProjects");
$details2Recordset1->execute();
<!doctype html>
<html>
<head>
</head>
<body>
<ul>
<li><?php echo($details2Recordset1->getColumnVal("client_name")); ?></li>
<li><?php echo($details2Recordset1->getColumnVal("project_name")); ?></li>
</ul>
</body>
</html>
The details data is showing for the first record only. When I click on the link from the masters page it will take me to the details page and list the first project, no matter what link I click on the masters list.
Jason Byrnes
On the details page, you have not set a filter for the record set (you did have the filter correct on the first one). the record set needs to filter the mission_id column using the mission_id URL variable being passed in the link.
Leon
Jason,
Thank you very much. I have added the filter by URL in the details page to match URL param in the master page to "mission_id"(unique identifier) per your advice and it has worked.
master link:
so the master page stays the same as previous step and the details page recordset reflects the filterby option in the Where statement. Correct?
$details2Recordset1->setQuery("SELECT * FROM completedProjects WHERE mission_id = ? ORDER BY project_name ASC");
$details2Recordset1->bindParam("i", "".(isset($_GET['mission_id'])?$_GET['mission_id']:"") ."", "-1"); //colname
<!doctype html>
<html>
<head>
</head>
<body>
<ul>
</ul>
</body>
</html>
See image. Also can use(just for my reference)
https://helpx.adobe.com/dreamweaver/using/building-master-detail-pages.html
Thanks for you help again Jason
