How to start with 1 table
Thread began 9/07/2009 7:21 am by meister281653 | Last modified 9/07/2009 5:28 pm by anonymous | 1852 views | 1 replies |
meister281653
I dont know how to start to create a 2 dynamic list with 1 table.
Where to start. I need to a video to see. I dont understand that english thats written in the tutorial. its to complicating.
how many recordsets are needed? 3?
I got it years ago with your help but lost the code.
php.php
here is the table:
venueID
province
city
venue
first selectbox, choose the province
second selectbox lists all the cities in that province, choose city
third selectbox lists all the venues in the city choose venue.
how to do that? I really dont understand that written tutorial.
Denis
anonymous
Denis,
You could use three queries, but then you would need to add some sort of a "submit" or trigger for each level.
The other way to do this is with a AJAX sort of query that wouldn't require hitting submit each time, but would require javascript on the end user side and would add page weight.
So with the first method, the first thing to do is to populate the "province" field... but you will only want each province listed once... so you would query for all records but for the province, make sure you use the "UNIQUE" SQL command sort of like this:
SELECT UNIQUE(province) AS provinceList FROM yourTable
Then you would repeat region or loop through your results of the provinceList column to give you your dropdown names and values.
Then once submit is pressed, the next round will involve query the results based on the province... something like this:
SELECT * WHERE province = "$_POST['dropdownName']"
Cheers,
Brian
