JSON nested repeat region - how to do it?
Thread began 1/21/2017 7:01 pm by Janet | Last modified 1/23/2017 5:06 pm by Ray Borduin | 3088 views | 11 replies |
Janet
I have a database table with one field that contains JSON . Each row of the database contains simple text fields called fields called TITLE, SUBTITLE, and DESCRIPTION, and the JSON data field called IMAGE
When the IMAGE JSON contains one image the following code works, but I have no clue how to add the code that would nest repeat all the images included in the JSON field as images.
The code I am using for single images per row is:
while(!$DETAILS->atEnd()) {
<div class="row">
<div class="col-md-8">
<h2><?php echo($DETAILS->getColumnVal("TITLE")); ?></h2>
<p><strong><?php echo($DETAILS->getColumnVal("SUBTITLE")); ?></strong></p>
<?php echo($DETAILS->getColumnVal("DESCRIPTION")); ?>
</div>
<div class="col-md-4">
<strong>
$json = $DETAILS->getColumnVal("IMAGE");
$myArray = json_decode($json, true);
<?php if ($DETAILS->getColumnVal("IMAGE") != "") { ?>
<img src="input/<?php echo $myImage = $myArray[0]["name"]; ?>" class="img-responsive center-block" alt="<?php echo $DETAILS->getColumnVal("TITLE"); ?>">
<?php } ?>
</div>
</div>
$DETAILS->moveNext();
$DETAILS->moveFirst(); //return RS to first record
An example of the 'multi-image' JSON is : [{"name":"images\/03_y8osnwim.jpg","usrName":"03.jpg","size":98665,"type":"image\/jpeg","thumbnail":"images\/th03_jdfcm55b.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":11684,"searchStr":"03.jpg,!11.jpg,!01.jpg,!12.jpg,!02.jpg,!13.jpg,!05.jpg,!14.jpg,!06.jpg,!:sStrEnd"},{"name":"images\/11_ipi01ygc.jpg","usrName":"11.jpg","size":96945,"type":"image\/jpeg","thumbnail":"images\/th11_g5cqaao1.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":12155},{"name":"images\/01_xv69cder.jpg","usrName":"01.jpg","size":98327,"type":"image\/jpeg","thumbnail":"images\/th01_bep2e90t.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":11359},{"name":"images\/12_mhancpnr.jpg","usrName":"12.jpg","size":104597,"type":"image\/jpeg","thumbnail":"images\/th12_4et19bu1.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":10972},{"name":"images\/02_j1bblk53.jpg","usrName":"02.jpg","size":123075,"type":"image\/jpeg","thumbnail":"images\/th02_midqduuw.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":13143},{"name":"images\/13_8iawh5dk.jpg","usrName":"13.jpg","size":108840,"type":"image\/jpeg","thumbnail":"images\/th13_ghuqpvtj.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":11991},{"name":"images\/05_ujgcogbd.jpg","usrName":"05.jpg","size":116858,"type":"image\/jpeg","thumbnail":"images\/th05_o319l82a.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":12247},{"name":"images\/14_lftyibpj.jpg","usrName":"14.jpg","size":127039,"type":"image\/jpeg","thumbnail":"images\/th14_5bzrctsz.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":11481},{"name":"images\/06_urku1k0z.jpg","usrName":"06.jpg","size":174727,"type":"image\/jpeg","thumbnail":"images\/th06_73yma7ny.jpg","thumbnail_type":"image\/jpeg","thumbnail_size":15751}]
Any advice you can give would be much appreciated. MySQLi and JSON newbie!
Janet
Just to update with an answer and a follow up question...
I finally found out how to turn the JSON into a repeat region in the php... this is my code:
$someJSON = $DETAILS->getColumnVal("IMAGE");
$someArray = json_decode($someJSON, true);
foreach ($someArray as $key => $value) {
echo "<a href=\"input/\" " . $value["name"].
"<div class=\"col-md-4\" style=\"margin-bottom: 5px\"><img src=\"input/" . $value["name"]."\" class=\"img-responsive\"></a> </div>";
and it works perfectly for the first row (web example sent privately)
But it won;t repeat the whole row - in fact, on every page I have added the json_decode the repeat region doesn't work.
Everything seems to be fine as far as I can see, I am not sure what I have done wrong. Can you advise? I have sent the pages as an attachment.
Thanks for a great product!
It looks like it should work to me. The only way I could debug any further would be to have a url and ftp access to a page where you have tried to do this and it isn't working. I could probably debug that and tell you why at that point.
Janet
With pleasure sir :) And with thanks too! Details attached privately.
What url should I be using to view the page with the problem?
Janet
www.sigwebdesign.com/boyce - it is a simple site and each page is very similar, each with its own database table
Just a little more background. So I'm assuming I should click on the gallery.php page and then on that page there are some missing images? Where is the problem that I'm supposed to be looking at? What is missing? What do you expect to see that you aren't seeing?
Janet
Hi Ray,
In the image gallery, and in the Christmas Trees page, there are two rows. The repeat region does not show the second rown. I started off this weekend asking about the json query, and finally found out my errors, but I can;t work out why the repeat region is not repeating.
Ok it is probably the same issue on both pages, so let's just work with one at a time anyway. I'm looking at the gallery page and I don't even see a repeat region applied.
Janet
on the trees.php page "Christmas Trees" it does have a repeart region, but doesn't show it.
I don't know why I did';t put the repeat region back on that gallery page. I removed it to solely work on the json section (so as not to confuse myself, as you can probably already imagine that is very easy to do)
I just know this is going to be something really stuupid I did wrong - been one of those weeks! LOL
