Javascript Error when updating *results.php
Thread began 3/31/2009 6:38 am by ellis.robert.j337464 | Last modified 9/08/2009 2:59 pm by Ray Borduin | 4885 views | 6 replies |
I have been having this issue for quite some time now and really need to nail down what is causing the issue. After running the DA wizard, if I go to the whatever_results.php page and try to update or edit the Recordset(WADAwhatever) server behavior, I am getting the following error message when leaving the edit mysql dialog box:
While executing applyServerBehavior in Recordset.htm, a JavaScript error occured.
Now I just tested this, and this happens regardless if I update the query or not. Just opening the edit query dialog and closing it causes this error. I am using the latest version of DA on Vista with DW CS4. I can manually edit the record set in code view, but would like to be able to do it via the dialog as intended. In the past I have done all sorts of things to try to correct this issue. Even went as far as to uninstall all the extensions and DW and start from scratch, to no avail. Any ideas?
Also, this only happens on the results page, all of the other pages, insert, update, search, etc, are all fine. I can edit any of the queries on any of the other pages without any errors.....
Bob
Please create a support incident. This problem was introduced in CS4. We have a quick solution that involves updating the Dreamweaver file that creates the problem. We will be implementing a fix in the individual extensions demonstrating this problem in a future dot release of those extensions.
fragop363190
I run into same problem while im trying to create a new Recordset so i do sth with related data in the results form.
I have opened a ticket please reply asap.
cpfusion
Have just encountered the same error. My ticket has been submitted.
roby258376
Same problem. Submitted ticket as well. Awaiting fix.
simmo515303621
I am having a similar issue
Trying to edit Insert Record behavior
I get the following Javascript Error.
While executing onLoad in WAAB_Insert_SB.htm, the following javascript error(s) ocurred:
In file "WAAB_Insert_SB":
initializeUI not defined
WHere do I create a supprot ticket or have I just done it:)
You need to delete your filecache .dat file.
showthread.php?t=3977&highlight=winfilecache+appdata
