IF / Else Statements With Data From Recordset
Thread began 3/17/2016 4:08 pm by Kevin | Last modified 3/21/2016 11:41 am by Ray Borduin | 913 views | 3 replies |
Kevin
Sorry for what is probably a dumb question. I have a recordset rsAccount and each row has a column called acctStatus that holds either a 1, 2, or 3.
Instead of just outputting the value of that field I'd like to get it into an IF/ELSEIF/ELSE statement that outputs "Hourly" if it is 1, "Retainer" if it is 2, and "Ad Hoc" if it is 3.
I've been trying for a couple hours and am getting nowhere.
Dave BuchholzBeta Tester
Kevin,
you would do it like this:
SELECT IF(field = 1,'Hourly', IF(field = 2, 'Retainer', 'AdHoc')) AS alias FROM table
basically anything that is not a value of 1 or 2 will be "AdHoc"
Hope that helps
Kevin
Dave,
Perfect. A thousand thanks.
Kevin
No problem, glad I could help
