css for form fields: modify form field sizes
i want to make some form fields bigger. there are several, but for instance the drop downs on boat_data_insert:some of the choices are longer than the form box. also notes on event_insert; the field is varchar 256 but it is a small box to type in. i am sure this is easy, and i have several others i want to modify. i have tried to find the class but not having luck. just cannot find the class(es) to modify. it would be cool if i could modify right at the particular box, rather than change class for all boxes on a page. thanks
