This extension can not be instaled, it requires Dreamweaver version 9 or greater.
Thread began 2/07/2016 5:22 pm by Christopher | Last modified 12/28/2020 9:53 am by Ray Borduin | 986 views | 3 replies |
Christopher
I just made this purchase and received the above mentioned error when I tried to install. I am running Dreamweaver CC 2015 and have the latest extension manager. I googled solutions and came up empty.
Christopher
Adobe Third Party Installer
I found a workaround for this issue. Go to the following website and follow instructions to install third party extensions:
https://helpx.adobe.com/creative-cloud/kb/installingextensionsandaddons.html
Pellumb
That is not the answer to dw cs6 . Adobe extension manager- cs6 installs other extensions without any problems but fails to install this freetools_115.zxp. instead brings up the above titled error. Webasisst either need fix it somehow or if it can not better just take it! No?
Version 9 is CS3... so I'm not sure why that message is coming up for you. Have you tried installing the CS3, CS4, and CS5 version? It should technically work in CS6 as well.
