Repeat Region does not work with complex queries
Thread began 1/25/2016 9:36 pm by Ron | Last modified 1/28/2016 7:48 pm by Ray Borduin | 912 views | 3 replies |
Ron
Repeat Region does not work with complex queries. Only 1 row is returned. When executing the same query in MySQL Workbench, the correct number of rows are returned.
WEBASSIST CODE:
$Recordset1->setQuery("SELECT * from variety LEFT JOIN testresults ON variety.variety_id = testresults.testresultsVariety_id
LEFT JOIN growingseasons ON testresultsGrowingSeasons_id = growingseasons_id
WHERE growingseasons_id = '3' ORDER BY variety.variety_id);
$Recordset1->execute();
HTML/PHP Code:
<ul id="list1">
while(!$Recordset1->atEnd()) {
<li><?php echo($Recordset1->getColumnVal("varietyName")); ?></li>
$Recordset1->moveNext();
$Recordset1->moveFirst(); //return RS to first record
</ul>
Total number of columns with the 3 tables are 44.
When declaring the recordset object (the line above the one you included) it has an argument of the maximum number of rows to return. If you set that to 0 it will return all rows... I'm assuming yours is set to 1.
Ron
Found the issue. It was the 0 vs. 1 in the Record Set. As complex queries don't consistently show up in the Bindings Panel, I recycled on and didn't change the 1 to 0.
Why doesn't modified/complex have weird display behaviors in the Bindings Panel?
I'm not sure. We tap into the native Dreamweaver code for doing those. Maybe we should redo them in a future update.
