Second Level flyout unwanted appears
Thread began 1/22/2016 3:59 pm by Charles | Last modified 1/25/2016 4:07 pm by Ray Borduin | 430 views | 2 replies |
Charles
If you look at http://outofchaos.net/gsc/www/index.php
Rollover the 'Products' Tab and then on the Products dropdown rollover 'Pennsyvannia Bluestone' and a 2nd level flyout appears at the top right of the Products dropdown. It's the only time this appears on any Products dropdown. This menu was generated by CSS Menuwriter and I tried commenting out "level-2"from lines 71 to 81 of the attached but that just destroys the whole menu. How could I change it so that 2nd level flyout does not appear? Your help is much appreciated. Thank you.
I'm not sure how you commented it out, but I think you can physically delete lines 53-80 to remove the sub-menu.
Charles
After trying several combinations, I found deleting lines 71 to 77 worked. Thank you.
