type=date
Does the the Server Behaviors support type=date such as: <input name="addEquipmentLastOil" type="date" />?
I am getting this dump and cant find the error:
object(WA_MySQLi_Query)#5 (19) { ["Connection"]=> object(mysqli)#1 (18) { ["affected_rows"]=> int(-1) ["client_info"]=> string(78) "mysqlnd 5.0.8-dev - 20102224 - $Id: 731e5b87ba42146a687c29995d2dfd8b4e40b325 $" ["client_version"]=> int(50008) ["connect_errno"]=> int(0) ["connect_error"]=> NULL ["errno"]=> int(0) ["error"]=> string(0) "" ["field_count"]=> int(0) ["host_info"]=> string(25) "localhost:3306 via TCP/IP" ["info"]=> NULL ["insert_id"]=> int(0) ["server_info"]=> string(10) "5.6.22-log" ["server_version"]=> int(50622) ["stat"]=> string(133) "Uptime: 5629 Threads: 1 Questions: 183 Slow queries: 0 Opens: 73 Flush tables: 1 Open tables: 66 Queries per second avg: 0.032" ["sqlstate"]=> string(5) "00000" ["protocol_version"]=> int(10) ["thread_id"]=> int(31) ["warning_count"]=> int(0) } ["Statement"]=> string(78) "INSERT INTO equipment (equipmentEquipmentType_id, equipmentYear) VALUES (?, ?)" ["Action"]=> string(6) "insert" ["Table"]=> string(9) "equipment" ["Filter"]=> string(0) "" ["SaveAs"]=> string(0) "" ["ParamTypes"]=> array(2) { [0]=> string(1) "i" [1]=> string(1) "i" } ["ParamColumns"]=> array(2) { [0]=> array(2) { [0]=> string(25) "equipmentEquipmentType_id" [1]=> bool(false) } [1]=> array(2) { [0]=> string(13) "equipmentYear" [1]=> bool(false) } } ["ParamValues"]=> array(2) { [0]=> string(1) "1" [1]=> string(4) "2016" } ["FilterValues"]=> array(0) { } ["AffectedRows"]=> int(-1) ["InsertID"]=> int(0) ["NumRows"]=> int(0) ["ParamCount"]=> int(2) ["FieldCount"]=> int(0) ["Error"]=> string(49) "Field 'equipment_id' doesn't have a default value" ["ErrorNo"]=> int(1364) ["ID"]=> int(2) ["Debug"]=> bool(false) }
PS: I know that type=date is chrome specific but I am using my app in house until I can find a good (easy) date picker.
