Trying to add a Category Description Field to products_results page
My company wants to add a field to the products_results page(attached) that shows a Category Description above the listed products results. So I added a Category_Description field to the 'category' table in the DB, entered some text in that field, and added that field to the SQL Select statement on the products_results page line 98 and then mimicked the code that properly renders the Category Name at the top of the products_results page line 336 but with it calling the Category_Description field - line 341. You can see the result at the test page
http://outofchaos.net/gsc/www/products_results11-24.php?Category_ID=6&Search=1
They want the Category_Description where you see 'Description goes here' on the test page above but it's not pulling the Category_Description field data. What would you suggest? Thank you.
