Putting a session variable into a recordset
Thread began 9/01/2009 12:04 pm by martin317528 | Last modified 9/02/2009 9:29 am by Jason Byrnes | 932 views | 1 replies |
martin317528
I've achieved two tables talking to each other before but struggling to make this situation work: Two database tables, one imported weekly with 50K records and one I've created to relate to it. I can create a details page I want manually but not dynamically. To do so I need to add a "LIKE" session variable into the WHERE clause of a recordset. EG:
"WHERE table1.field1 LIKE '%exampleText1%' AND table2.fieldB $_SESSION['exampleTextB']
I'd add a numeric field to the larger imported table that relates to mine but I would need to manually do this 50K times. Or, look to write some php to get the table as I need it but being able to use it as it comes will help as I'm importing such a large table so often.
Question is, is there another way to do this or can I have an example of how to add the session code into the recordset.
When creating the recordset in dreamwever using the Advanced view, to use a session variable, you need to create a variable in the recordset.
Create the SQL as:
WHERE table1.field1 LIKE '%exampleText1%' AND table2.fieldB LIKE '%paramSession%'
The click the plus button in the variable section:
Type: Integer
Defualt Value: -1
Run Time Value: $_SESSION['exampleTextB']
This will cause "paramSession" in the SQL Above to be replaced with the value stored in the session variable if it is set or -1 if it is not.
