Don't display field with no data
Thread began 9/10/2015 12:35 pm by Charles | Last modified 9/14/2015 11:57 am by Ray Borduin | 718 views | 2 replies |
Charles
If you look at this URL you'll see a field at the bottom that says 'Specification: Click to view.' http://outofchaos.net/gsc/www/products_detail.php?ID=17
This allows user to click to view a PDF. However, if there is no entry in the DB for the Specification('Spec_PDF_Name') line 300 of attached file, I'd like to not have that line appear at all. Is there a piece of code I can add to have the Specification line appear only when that field is filled in the DB? Thank you for your help.
Change line 300 to:
<?php if ($row_WADAproducts['Spec_PDF_Name']) { ?>
<div class="WADADetailsLongDesc">Specification: <a href="images/<?php echo($row_WADAproducts['Spec_PDF_Name']); ?>" title="Spec-PDF" target="new">Click to View</a></div>
<?php ?>
Charles
Beautiful - that works nicely now. Thanks again.
