1. How to use eCart eCommerce MySQL database to record the data? 2. Has it "Admin login" to view and manage the data?
Thread began 9/06/2015 1:49 pm by Shawn | Last modified 10/24/2017 10:28 am by Ray Borduin | 2669 views | 13 replies |
Shawn
I have tried the "Check out wizard" to see the database options, but it always says: "Please insert an eCart Display at least once in this site before using the wizard." What means by "insert an eCart Display at least once"?
It means go to "WebAssist->eCart->Display Manager" and run that wizard on a page where you want your cart displayed before trying to run the Checkout Wizard.
Shawn
I added a "Add to cart" button to my page, and clicked the ""WebAssist->eCart->Display Manager" , it just add a piece of gray code to the page, then tried "Checkout Wizard", it still shows "Please insert an eCart Display at least once in this site before using the wizard."
It shouldn't add a piece of grey code, it should add an entire cart display with all the items in the cart listed, a sub-total and total and update functionality to update quantity and remove items. Something is wrong in the Display Cart step.
Does the display manager open? Are there any errors or messages? The real problem here is that the display manager isn't running correctly. If you post a US phone number or Skype contact information I can set up a screen sharing session so you can show me what you are seeing. I've never heard of a problem like yours, so I'll have to debug it directly to figure out what is going on.
Steve
Same issues here... Fresh install of the latest eCart and only commented out snippets and no means to create the Checkout page from the wizard :-(
Steve
Fails in similar fashion using CS6 as well as 2018CC
You have to create a display cart first before running the checkout wizard. You can even create it on a new page and delete the page later. It uses the design settings you chose when doing the eCart display when creating the checkout experience.
Steve
Yes, that is even the page showing no Display Cart addition, only comments...
The page I am working on is called Display.php and here are the contents:
//WA eCart Include
require_once("../WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
$ATC_itemName = "";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("0");// column binding
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
if (function_exists("rel2abs")) $eCart1->redirStr = rel2abs($eCart1->redirStr,dirname(__FILE__));
header("Location: ".$eCart1->redirStr);
die();
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
<title>eCart Updateable Text Field</title>
</head>
<body>
<!--MENU-LOCATION=NONE-->
- File Name:
- WA eCart 02Display.htm
- Description:
- Opens the Display Manager
- This file contains proprietary and confidential information from WebAssist.com
- corporation. Any unauthorized reuse, reproduction, or modification without
- the prior written consent of WebAssist.com is strictly prohibited.
- Copyright 2002 WebAssist.com Corporation. All rights reserved.
<form name="eCart1_1_ATC_0" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentities($_SERVER["QUERY_STRING"]):""; ?>">
<p>
<input type="hidden" name="eCart1_1_ID_Add" value="0" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<input type="submit" class="eC_FormButton" value="Add to Cart" name="eCart1_1_ATC">
</p>
<p>&nbsp;</p>
<p>
- File Name:
- WA eCart 10RedCO.htm
- Description:
- Opens the Redirect Checkout UI
- File Name:
- WA13_eCart_PostForm.htm
- Description:
- Opens the UI for Post Cart in Form
- Copyright 2004 WebAssist.com Corporation. All rights reserved.
- File Name:
- Description:
- File Name:
- Description:
</p>
<p>
- File Name:
- Description:
<input type="submit" name="submit" id="submit" value="Submit">
- File Name:
- Description:
- File Name:
- Description:
<!-- MENU-LOCATION=NONE -->
- File Name:
- WA eCart 03View.htm
- Description:
- Opens View Cart Command
</p>
<p>&nbsp;</p>
<p>
- File Name:
- WA06_eCart_Edit.htm
- Description:
- Inserts WA eCart Updateable Text Field
<!DOCTYPE HTML SYSTEM "-//Macromedia//DWExtension layout-engine 5.0//dialog">
</p>
<p>
- File Name:
- Description:
</p>
</form>
</body>
</html>
Try creating a new display. After it is created it should create an .xml file in your WA_eCart folder where the design settings are saved. The error you are getting means that WA_DMCFG.xml file isn't there for some reason. Re-running the display manager on a blank page should create the necessary .xml file and allow you to complete the checkout wizard.
Steve
"Create new display"... Not sure I am following you.
I create a new page (display2.php) and then use the Display Manager as shown in the screen:
