product results doesn't show 2nd page correctly
Pagination issue with products_results.php:
At first page 2 of the product results showed 'no results' when items were there.
Searched WA forums and found solution at http://www.webassist.com/forums/posts.php?id=36460 which had me move the <php? pagination code to after the recordset. This solution worked previously when I used it to correct the product_results for our products admin.
However, when we did same for the public products_results page, we get some funky code appearing on page 2 of the results('pageNum_WADAproducts=1') in the visible header - see http://outofchaos.net/gsc/www/products_results-p2test.php?pageNum_WADAproducts=1&totalRows_WADAproducts=24&Category_ID=29&Search=1
Whereas page 1 of the results is clean - http://outofchaos.net/gsc/www/products_results-p2test.php?Category_ID=29&Search=1
Would appreciate your help here. Copy of the file is attached.
