Power Gallery edit/remove title and border
Thread began 8/13/2015 7:59 am by Charles | Last modified 8/18/2015 10:27 am by Ray Borduin | 1597 views | 11 replies |
Charles
Created a slideshow_blinds for the attached site home page. Need to make the following changes to make it usable. How can we remove the title and image name that appears under the image and eliminate the border around the image(it pushes the rest of the page design down too far)? Also attached is the slideshow index.php if that helps.
Thanks for your help.
You could probably do it with an update to your .css file. Do you have a url where I can see the live page with the slideshow that has the border and title you want removed? That would be the best way for me to debug what .css updates are necessary.
Charles
The URL is in PM below. Besides removing the border, title and file name, I'd like to remove the Progress Bar and slow the rate of the image changes if possible. Thank you again for your help!
Edit the js file
You will see on the top of the page where you can turn off the caption, progress bar, and change the delay time between frames.
Charles
The page you reference, index2, is the index page I gave you. In that page I embedded the include I got from addtosite.php in PM below. So there is no place on index2 itself to make the edits you reference and I don't see where in the embedded /slideshow_blinds/index.php(attached) to make the edits you suggest. Maybe you could point me to which of the files nested in /slideshow_blinds/index.php contains the border, title, etc that can be edited?
Thank you
The page I meant to update is: /gallery/galleries/slideshow_blinds/js/gallery.js
Look at that file and you will see the settings I'm talking about.
Charles
That worked - looks good now. Thank you!
Meanwhile we created a 2nd Gallery(grid_fullsize) at the URL in PM below. We only want to remove the filename from below the feature pic - everything else is good, but I don't see that option in the corresponding /gallery/galleries/grid_fullsize/js/gallery.js
What could you suggest for this last itty bitty?
Thank you
Charles
Attaching a copy of the .js file in question for /gallery/galleries/grid_fullsize/js/gallery.js - not seeing the toggles in the Options' section that were in /slideshow_blinds/js/gallery.js - just looking to turn off the filename from appearing both under the feature pic and on the rollovers of the thumbnail images.
Thanks for any direction here.
gallery.js
This change will be done on the gallery's index.php page. Please attach a copy of that page and I can suggest where to update it.
Charles
Attached. Thank you
index.php
