add to cart button on all products page
I have an Add to Cart button on my Product Details page. Is it possible to also have Add to Cart beneath each item on my All Products page?
Yes. This is relatively common and I believe it is done in the free webinar linked from your eCart downloads page.
Yeah, I looked there first, but the only webinar I can find for placing an Add To Cart button had me putting it on the Detail page (http://www.webassist.com/tutorials/Add-a-shopping-cart-II--eCommerce-Series-). When I try to do it on the All Products page - it doesn't work.
I think the main issue could be that no choices are showing up in the ID Column of the wizard - although it's certainly in the record set. I will attach the page so maybe you can see something I'm missing.
It doesn't look like there is an add to cart button on this page at all yet.
What happens when you try to add the button? Can you open and test the recordset without issues? What exactly do you mean by "It doesn't work"?
Got it working Ray. I think the problem was that, for some reason, the record set on this page was not a WADA.
