Products button to show ALL Categories
Thread began 7/22/2015 1:32 pm by Charles | Last modified 8/24/2015 10:45 am by Ray Borduin | 2201 views | 13 replies |
Charles
I have the 'Products' dropdown menu and products_results and products_detail working fine - see http://outofchaos.net/gsc/www/index.html
However if you just click the 'Products' button itself and not one of the dropdown options, it yields a dead result, I'd like it to link to a page that showed all categories something like http://outofchaos.net/gsc/www/products_results.php?Category_ID=?ALL? but I'm not sure what the syntax is that would yield the ?ALL? Could you suggest what it should be? Thank you
Please attach a copy of the results page you are using. I'd have to take a look at how it works to suggest how to get an ALL link implemented.
Charles
Here's a link and file is attached: http://outofchaos.net/gsc/www/products_results.php?Category_ID=32
Thank you!
Remove the where clause from the query and add the Category_ID column search to the DataAssist Search server behavior. The DataAssist Search will automatically ignore columns that aren't in the filter.
So line 114 becomes:
$query_WADAproducts = "SELECT category.Category, ID, Small_pic_Name, Product_Name, Product_Name, Description, Color FROM products INNER JOIN category ON category.Category_ID = products.Category_ID ORDER BY Product_Name ASC";
and then you add this to line 23:
$WADbSearch1->addComparisonFromEdit("products.Category_ID","Category_ID","AND","=",0);
Then a link to a category could be: product_results.php?Search=1&Cateogry_ID=3
and a link to show all categories would just be: product_results.php?Search=1
Charles
Almost. I found not to get an error, I had to adjust your suggestion for line 144 to $query_WADAproducts = sprintf("SELECT category.Category, ID, Small_pic_Name, Product_Name, Product_Name, Description, Color FROM products INNER JOIN category ON category.Category_ID = products.Category_ID ORDER BY Product_Name ASC" - I think you were mississing the 'sprinf'
I added the line 23
Not sure I understood how much of the Where clause to remove? I removed from line 11 - $WADbSearch1_DefaultWhere = "";
File is attacheed with the above changes
So now I am getting all products/all categories for all products_results.php??? pages - not filtering by category in the dropdown.
What am I missing? Please advise or perhaps correct the attached file.
Thank You!
products_results8-6changes.php
Do you have a url where I can reproduce the problem? I need to see if it is an issue with the search or results page and seeing it in action may help.
Charles
See PM
You have to add "&Search=1" to the URL. Then it will know to do the search and it seems to work.
Charles
I can see that when I add "&Search=1" to the URL manually in the address bar, that it does yield a correct Category-filtered result, but I'm not sure where in the code of products_results.php to insert it so it automatically generates that correct URL. Tried a few places, but didn't work. Could you point me to where it should go? Reattaching file. Thank you.
It looks like the menu links come from:
CSSMenuWriter/cssmw3/menu.php
you would add the url parameter to the links in that file.
