Look up item id from recordset' radio button option is not available with MySqli server behaviors.
Thread began 7/13/2015 6:47 am by paul | Last modified 7/13/2015 1:53 pm by Ray Borduin | 311 views | 1 replies |
paul
After adding / upgrading to "MySqli server behaviors" to ecart the 'Look up item id from recordset' radio button option is not available. Everything else is seems to be fine. It is working the o;d way fine using the mysql record sets but going through the same routine with the mySqli behaviors options means that the 'Look up item id from recordset' radio button option is just not available.
I have tried moving the rsobj.php contents in with the source code to see if it was not seeing the recordset but no change. I am using mac osx 10.6.8. Making a recordset with msqli tests fine...
Have you updated your eCart version to v6 and reinstalled lately? We have updated eCart 6 to work with MySQLi recordsets, so provided you have the latest version this should be working for you.
I just tested and it appears to be working properly for me.
