MySQL Rights for cms database user?
What minimum rights in mySQL does the cms database user need? Right now it is set to DBA but I'm not sure if it needs that level of rights. Thx
The first time it runs it needs the rights to create tables and modify. After running once, the tables are created and it only needs to be able to modify data in the existing tables.
